What hits lower frequencies
Username: Lanzarchamp
Bakersfield, California United States
is it the ported sealed vented or the bandpass
Username: Carguy
Post Number: 4469
Are you looking for noise or SQ?
Of course ported/vented will sound louder than sealed.
Depending on the setup, bandpass can sound horrible.
Username: Sploosh56
Ohio
Post Number: 942
ported in my opinion is the easiest box to get great sound and deep bass from
well i wanted to know because my box just blew up and it was 3/4 " mdf all th eway around and it was vented, i want the same box but 1.5 cu. ft' each side, with 1"mdf, anyone know of any sites or people, ill take what i can get
Username: Rovin
Trinidad & T...
Post Number: 942
Very easy to build , man - only 1/2 of a day's work ...
Post Number: 7
so do you know of any place
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 157
from what i understand sealed boxes will technically hit lower frequencies then ported or bandpass. but w/ ported you tune the box to a certain frequency to give it a boost at that frequency so it is a louder setup.
are you depending on internal resonance to amp the sound of a lower frequency in a sealed box vs. a ported box?
i can imagine that leak
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 160
no i'm saying if your doin a bass cd or somethin and you bottom out the subs in a well designed professionally made sealed enclosure granted the subs are decent and you don't have a subsonic filter on the amp the subs should go as low as they are meant to play. and in a ported box the sound will " cut off" at some point depedning on the box's tuning Frequency. this is what i've been told by local MECP installers
i have never used ported b/c i have always had multiple subs and small cars
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10619
sealed will play the deepest.
anything ported or bandpass rolls off steeply or has to be filtered just below the tuned frequency.
The tuned frequency should, and usually is higher than the Fs of the driver as well.
