Pioneer DEH-670MP vs DEH-P770MP
Username: Ronh3
Hey Ecoustics experts, long time reader, first time poster. I had a question about the actual differences between these two units, which both seem to be highly recommended on near all comparisons vs Alpine, etc for their price range. Comparing the two, I saw that the 770 has 4v preout vs 2.2v on the 670. If I intend to install an amplifier anyways, will that make a difference? At the moment, all I have in my car (1991 Honda Civic Hatch) is a set of Infinity's in the door (not positive on the model, can double check). The price difference between the two, so far as I can tell, is about $70. Is the 770 worth that extra $70? Thanks a ton in advance.
Username: Taylor17
Kopperl, Texas
Post Number: 2987
I'm using the 670, with 2 amps... and it does the job just fine... I really like the 960 though.:-)
If you don't really care about the extra $70, then I'd go with the 770.
