Bast cheap 12' subs to buy
Username: Ironslave
i need to find me a nice pair of 12" subs to go with my amp... but i am on a really really tight budget... any suggestions
AMP Specs:
980W peak power, bridged
560W RMS (continuous) x 1
280W RMS (continuous) x 2 @ 2 ohms
220W RMS (continuous) x 2 @ 4 ohms
i am looking at geting subs with 4 ohm load, not run parallel.
i hooked up a lightning audio storm series set. 700Watts, 150RMS they hit hella hard... but after about 2 months i blew the voice coils out.
Username: Dz4389
Post Number: 8
what exactly is ur budget?
Username: Ironslave
bout 100$
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 136
A little more than your budget but should still get the job done
http://cgi.ebay.com/2-ALPINE-SWS-1242D-Type-S-12-DVC-SUBS-NEW_W0QQitemZ581167891 5QQcategoryZ18803QQrdZ1QQcmdZViewItem
Username: Ironslave
grrr. to big for my box.. 5.5" max size i can use. it's 1 inch to deep.
thnx man.
Username: Rideredder
Cornell, IL USA
Post Number: 9
go to www.internetsoundsolutions.com and look around.
Username: Ironslave
how bout boss rt'12s?
i am looking for hard hitting... i bought a set of duals with 600RMS and 1200 Peek... they sucked... the lightning audios i got were 750 watt@150 RMS and sounded great....
Post Number: 138
James look at this
http://pub14.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=27.topic
Someone38875
I have a question is internetsoundsolutions.com a reliable website? Cuz it looks kind of hokey
Post Number: 139
try ikesounds.com
Username: Comp98
Philadelphia, PA USA
Post Number: 17
why not get a single RE RE12. $69 before shipping. Save up your money to get another one later on.
Username: Ironslave
cool... thanks,helps me out a bunch... now for the next question... this site mark pointed me to has an earthquake tremor12 for 60$.the specs it does have make no sense to me....
heres the listed specs
* Fs = 27Hz
* Qms = 5.396
* Qes = 0.642
* Qts = 0.574
* VAS = 3.4Ft 92 liters
* Xmax = 0.5"
* 87dB 1W/1M
* Revc = 6.5
* Levc = 5.9mH @ (1 kHz).
* Single Voice coil/8ohms
also... running at 8ohms.... what does this mean to me since i am running on a low end amp
Username: Ironslave
re re12?
Username: Robert_d
MIA, FL USA
Post Number: 130
get a type R off ebay its 110 wit shippin
Username: Basshead86
Ocala, FL USA
Post Number: 1637
very little power, but way better reliability.
Username: Robert_d
MIA, FL USA
Post Number: 132
naw i ment bridge the amp so its runnin 560rms to the type r (500rms)
Username: Ironslave
Post Number: 7
i think i am going to get the earthquake tremor12 this should work out ok... i think.
Username: Ironslave
Post Number: 8
hey mark i was wondering if you had ever ordered from www.internetsoundsolutions.com.
i'm curious as to how long it took to get the package...
Cornell, IL USA
Post Number: 11
Yes, i have bought stuff from there. Shipping usually takes about a week, depending on what day you order your stuff.
Username: Swishblank88
Vashon Island, WA USA
Post Number: 10
What about two Infinity 12" References? you could get them for 100$ im sure and im not sure about mounting depth tho...
Username: Redbone15367
Mo U.S.A.
Go to walmart.com look up elf-12 it's a power acoustic spl. I know that they are raited as bad but they do sound good. You can get them shipped for about $110. They are dvc but you can run them at 1, 2 or 4 ohm.
Username: Opie_har
Somewhere, One of them USA
Post Number: 101
Personally, I wouldn't buy any speakers from walmart.
Username: Ironslave
Post Number: 9
yea... did the walmart thing... thaats why i need new subs.... i am just looking for something that hits hard... i ended up buying a rockford sub from a guy... it still hits like crap... i an getting curious as to weather i am having some issues with other components... but i am moving my subs from a van (open space) to a honda accord (trunk, closed space) so i am wondering is its just me being paranoid...
fonsworth
have u guys herd anythign about massive subs and amps?
Username: Ironslave
Post Number: 15
i'm just looking for something to vibrate my mirrors off my car :-)
Username: Matt12490
Benicia, California
Post Number: 260
This gives us a very limited amount of subs to choose from. Your best bet would be to go with an alpine type R or 2 infinity refs
