Help adjusting amplifier
swissahouse
i have a 12" in a sealed box how do i set all my adjustments on the amplifier
theres:
gain
x-over
subsonic
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1066
http://www.cdtaudio.com/set-up_ampgain.htm
http://www.caraudio911.com/
"tweeking your bass" and "subsonic filters"
it's sealed though, so the air will protect your subs. really no need for a filter.
xo is personal. i like mine at 63 hz. most set theirs at 80hz. depends on what you're running. just listen
