System in a hybrid?
Username: Terps297
Potomac, MD USA
Post Number: 138
how would this work since when the car is moving below a certain speed, it turns to electric...if that is so, how would it effect a hi wattage system in a car? I do not have plans on buying a hybrid and i don't have one now, but i was just curious
CARAUDIO
extra or bigger battery for shore and a better alternator.
If anything dont go over 1500watts RMS for shore. If you hit high way then you could crank up the power on your system.
Username: Lbeckner
Tulsa, Ok Usa
Post Number: 427
wonder if you could just use the battery that runs the motor?
Username: Scubasteve
College Park, MD
Post Number: 611
worst idea of all time. Lets just put this one past us guys and pretend it never happened.
