Amp question
Username: 94celica
Hanover, Pa United States
Post Number: 10
Can a MXA4002 amp power 2 MZS1204 subs? here is some information on them...
MXA4002 amp-Power Output:
100 Watts RMS x 2 channels at 4 Ohms U 1%
200 Watts RMS x 2 channels at 2 Ohms U 1%
400 Watts RMS x 1 channel bridged at 4 Ohms U 1%
MZS1204 sub-
RMS power- 300 watt
Sensitivity- 90.0 dB
Voice Coil- 1.8"
Frequency Response- 29-150Hz
Rec. RMS Amplifier Power- 150-300 watts
email is lineskis@hotmail.com
Username: Illuminator
Post Number: 1779
It might be slightly underpowered...but we won't know for sure until you post what the ohm rating is on the sub(including whether it is a dual voice coil[DVC] or single voice coil[SVC]).
nick_sq
if you can wire the subs to a 2 ohm load each, then run the amp stereo mode (2 channel) then it will push the subs fine.
