NEWBIE question: how do i install this used head unit
Username: Zobsky
Dallas, Tx
Hi,
I bought a used eclipse CD3424 off ebay with an intent to install in a 98 BMW 3 series car.
reading through the supplied manual, there are mentions of mounting brackets and front bezels which I can't find in the shipment.
Question: do I need these for my particular car and if so, where can I buy them?
Thanks, Vin
Username: Zobsky
Dallas, Tx
PS. I'll be getting the harnass next week, this post mainly pertains to the physical installation in the console
Username: Illuminator
Post Number: 1711
Yeah...you'll definitely be needing the mounting brackets...
What mounting accessories did you receive? The trim ring, the mounting cage, the screws/clips for the mounting cage?
Username: Jundi
Post Number: 20
you probably need a dash kit and antenna adapter too
Username: Zobsky
Dallas, Tx
hi,
got no mounting accessories :-(
where can i usually pick these items up from?
thanks, vin
Post Number: 1721
Ebay would be my first suggestion. Some car audio shops might carry them as well.
