What type of glue?
Username: Iufan4lifeul
Post Number: 440
What type of glue should I use to seal all around my subwoofer and in between the foam on the steel surround and the steel surround? The foam around the woofer (and RE 12) has come loose in a couple areas. What type of glue should I use?
Username: Phuktupbasshead
Scottsdale, Arizona United State...
Post Number: 276
I wish i could answer that, but it seems like you'll be telling me when you find out, because I 've been unable to.
Username: Lowrollins10
Champaign, IL
Post Number: 107
Use some of that 3M STRIP CAULK it doesnt dry and you can remove it from your speakers if you ever want to change it.
Username: Fordpwr
Los angeles, CA Usa
Post Number: 354
Just call up RE(if you bought it from them) and they'll send you a bottle of glue, free of charge.
