Box Help
Say My box is 16 x 16 x 13 On the outside using 3/4" board Its bigger then 1 foot volume right, So what if I drill some wood inside the box down securly and out of the way of the sub to displace the air in there. Is that a problem? Would be easier then spending money on a new sub box.
Username: Invain
Michigan United States
Post Number: 3687
Yes, you can add wood to the box. As long as it doesn't interfere with the sub you should be fine.
Username: Infinity_addict
Santa Rosa, California USA
Post Number: 166
yes! especially if you're going to get more powerful subs. read up on "bracing" yer box, cuz you wouldnt want it flying apart!
Username: Invain
Post Number: 3690
You shouldn't have to worry about bracing a little 1 cf sealed box, as long as it's 3/4" MDF.
You see bracing more when your dealing with a really large box and a heavy sub with lots of output. Something like a 40 lb sub in a 5 cf ported box. Then you'd definitely want to consider bracing.
