1 type r aginst 2 kicker comp's
Username: Biggyg9712
Post Number: 39
my friend has 2 kicker comps powere by a fosgate 300 watt rms amp, and i have a type r 12'' at 500 rms and its powered by a mrd-m605, sound wise, his system killed mine, and mine is running 200 more watts, why did this happen?
Username: Cenus
Hicksville, Ohio Usa
Post Number: 475
it must be your box.
Username: Robert_d
MIA, FL USA
Post Number: 46
could be ...
- a better box
- didnt tune amp correctly
- not using the right ohm
- cheap cables not supplying enough current
- configuration on head units
- type of car (like hatchbacks tend to be the loudest cause it doenst have a consealed trunk)
Username: Jakeyplaysbass
Post Number: 29
First off the two kickers will most likely be louder than one alpine...expecially if he has the T3002 amp...ive heard the kickers sound pretty good (for kickers) in a car before but it all depends on the box...i also agree with robert and the list of things things he posted.
Post Number: 40
ya he had a hatchback, i was thinking of getting dynamat. has anyone used it and is it worth getting? because right now i can almost hear as much rattle as i can bass
Username: Robert_d
MIA, FL USA
Post Number: 50
then yea u dynamat helps alot but u need couple of layers and also try to locate what rattles and see if you can put something under or over or take stuff away to help with the rattling
in my car it was a couple of metal screws hittin the chasis of the car on the back dashboard
Post Number: 41
does the dynamat make the bass louder
Username: Gpz1100
Post Number: 56
What kind of car you got?
The rear of a hatch back has quite a bit of natural gain in itself.
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 241
i would suggest getting eDead...just as good but cheaper..and to answer your question dynamat does tend to make the bass louder since your containing the music inside of the car and not letting it escape outside
Post Number: 42
i got a 2003 4 door camry, and where can i buy eDead?
Username: Quickshot
Post Number: 242
http://www.edesignaudio.com/category.php?type=damp&cur=USD
