Two 15" SX or One 15" MT ???
Username: Rickeyd87
Post Number: 26
which would be louder? i already have two 15" SX but only one of them is hooked up...never had time to build another box...how much more of a difference will there be by adding a second 15" SX with a seperate amp...
Username: Robert_d
MIA, FL USA
Post Number: 45
MT's theres really no specifications cause theres so many configurations (thats what re says) and most ive heard someone put to it was 2500 rms but im not to sure with that sub
if u get another SX it would add +6 db ... twice the bass
Username: Carguy
Post Number: 4285
One MT should be as loud as two of those in a proper box.
MT is 2500w - 5000w. 2x the power of SX.
Username: Robert_d
MIA, FL USA
Post Number: 48
isaac your talking about 5000w max or rms ?!?!
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 870
hes talkin RMS... ive HEARD of MTs taking 15000w rms burps...
oh and issac u have an MT right? whats the xmax on it do you know?
Username: Robert_d
MIA, FL USA
Post Number: 49
thats just wtf ...
Username: Carguy
Post Number: 4287
Yes I do have 15" MT. Don't have the xmax cause I couldn't get it from RE.
2500w rms for everyday use, and 5000w (2500w per vc).
