Orion Amps
aboooo abooooo
Yall all talk very good things about Orion amps, I believe mostly the old stuff.. But what about the XTR series? THey are relatively "cheap" on ebay, (refurbied). Just wondering if they are decent. thanks
Username: Invain
Michigan United States
Post Number: 3666
The newer stuff is decent. Definitely not what it used to be, but they're still good.
aboooo abooooo
better than say, hifonics?
Username: Invain
Post Number: 3669
Probably, yes.
aboooo abooooo
anyobdy else? anybody have experience with them? the XTR pro 1000 is rated at 1000x1 at 1ohm. the fuse rating is 40a x 2. Do you think it is "safe" to run it at 1 ohm for extended periods of time (daily driving) and what do you think its output would be? Also, do you think it would be a fairly clean signal.
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 231
i cant comment on that specific amplifier but yes its true that their not what they used to be but their still several steps above hifonics and it probably is ok to run them at 1ohm daily
aboooo abooooo
I dunno. Looking for a good 800-900rms at 1 or 4ohms. Might just go with the infinity 1211a and run it at 4ohms. same price on ebay
Username: Tjmutlow
Post Number: 27
have to question, Who refurb them, Orion has not fixed their product in awhile.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10235
the XTR line of amplifiers like you're talking about are good amps, and yes better than a hifonics.
they are DEI made amplifiers, but most of the XTR line was still USA made..
