Help alpine 9813
Username: Mesa50w
Charleston, Sc Us
any of you guys have this head unit? I've tried a few setting that i found on the web but I still have to much treble. I never had a stereo set up before so I'm new to all of it, I'm used to a settings for bass, med, treb. So I'm pretty lost with it, any help anyone could other up when be great.
this is my set up
I have a old alpine 3311 cross over/EQ. Should I put it in to help with cutting the highs?
alpine 9813
JL audio e4300
boston acoutics 6.5 compents (fr doors)
power acoustic 10"
power acoustic 5" (R doors)
Username: Illuminator
Post Number: 1583
Have you tried pressing the volume switch?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10132
the components can be set to about 120Hz high-pass, 12dB slope
turn off any EQ presets, and disable the MX feature.
if the comps are still too bright, use the parametric EQ feature to decrease the treble range a bit on the head unit.
it's all in the manual for how to access these settings.
you can also download the manual in PDF form from alpine1.com in the archives
