I want to drop around a 1000 on a thumpin system, what is gonna hit?
Ok, i have a limit of around a grand for a system. I was looking at some fosgate power t2's, but im kinda a beginer at this. So give me some feedback on what you guys think on subs if im looking for LOTS of spl, but a fair amount of sql as well. Also what kind of amp and box do you think will bump. What would you get with a grand??? And im buying on ebay so it wont be retail. thanks a bunch.
Username: Riebread77
Post Number: 621
I'd go with a pair of RE SE 15's...loud with a bit of SQ...and get a crossfire vr2000d...2000 watts rms @ 2 ohms...solid amp and solid subs...that will give you what you want for under a grand...
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 340
What do you want to include in a grand?
HU
HU dash kit
HU wiring harness
AMP (Components)
AMP(Sub)
AMP wiring kit('s)
Capacitor
HO Alternator
Component set
Sub
Sub enclosure
Dynamat
Kik pods
I'm sure theres other misc things that may be added, but still, if you re looking for the basic 3 (HU, Amp, and Sub), you may end up gettin an ok system for a grand. But if you re looking at gettin more than just the basic 3, then you will end up gettin stuff that you will not be happy with. Basicly, you get what you pay for.
