Time Alignment Processor
M0
Hi,
I am looking for a separete component that can control time alignment. I have looked at the Pioneer DEQ 9200, but is there anything else out there that can do the same thing...
The link for the Pioneer is
2076_4053_35804%2C00.html,http://www.pioneerelectronics.com/pna/product/detail/0 ,,2076_4053_35804,00.html
Regards
Mo
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 7532
Alpine's F#1Status processors can do this, but you need to use their head unit and amplifiers as well if I recall. I think someone else makes a time alignment processor but the manufacturer is eluding memory.
M0
Thanks for the reply.
Unfortuately I have all of the components installed in the car so buying new components is not an option right now.
If you do remember the manufacturers name please let me know ASAP...
Thanks for your time...
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 855
alpine's rux-h701 will also handle ta well.
or to a slightly lesser extent, (at least) their 983x HU's.
