Help Is my headunit broken
Hi, today I was working on my subs then they played but after I placed my seat back my head unit does not turn on any more. If I insert a cd and press the eject the cd comes out but my clock and my head unit do not turn on. Is there something I could have pulled by accident because I had to yank out the rear seat belt but I checked the wiring and it seemed fine. Is it just a fuse? Or is my head unit dead?
Username: Riebread77
Post Number: 556
check your illumination wire from your headunit...it may have come undone
Username: Punjavi_doo
or a loose wire
Username: Illuminator
Post Number: 1555
It's most likely the ignition wire (red). The unit will partially function with the battery constant (yellow) still hooked up.
