Confused about Amps
2002AccordEX
1. Does 55 watt RMS that can handle 275 watts max stand for the pair or each speaker?
2. Will the Orion 2002 rated at 2 x 50 watt RMS underpower those speakers? The 2002 only has 200 watts max power.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9855
forget max ratings.. totally.
always go by RMS for everything.
the Orion is fine for those speakers.. the ratings are thermal, and usually per speaker.
http://www.wickedcases.com/caraudio/speakerpwr.html
