Cast your votes: Best SQL Sub on the Market
Username: Phuktupbasshead
Scottsdale, Arizona United State...
Post Number: 217
For this one, price should not be an issue... please vote to indicate YOUR CHOICE for BEST SQL SUB ON THE MARKET. Your expertise, knowledge, first hand experience, and opinions are greatly valued and appreciated. First hand experience is, without a doubt, the most accurate vote - however all input is welcome. An explanation for your vote is not required, but encouraged.
We thank you very much for participating.
Voting results will be revealed within 1 week.
Username: Suleman36
Maryland U.S.A.
Post Number: 2096
Resonant Engineering XXX
Username: Subfanatic
Ky
Post Number: 4792
Eclipse Ti
Username: Jundi
Post Number: 11
W7 you can't beat it
Username: Acevolkov
Springfield, Missouri United Stated
Post Number: 116
its the XXX. w7's too expensive, and the IDMAX isnt as loud and clear as the XXX.
Username: Mtxaudiouser
Post Number: 14
XXX
Username: Rhassler
Gilford, NH
Post Number: 357
RE XXX
Username: Jonathan_f
GA USA
Post Number: 4510
ID Max. Very flexible enclosure capabilities, excellent musicality, excellent transition with midbass drivers, especially above 60hz (my main gripe with the Brahma and XXX, which get muddy above 60hz), low resonant frequency. Very efficient as well.
CaptonDillWeed
Sony Xplod
Post Number: 221
Unfortunately, unregistered guest votes will not likely be accepted for this reason (above)
Unregistererd voters are still welcome, but I can only do my best weeding through them.
Capton America may have fooled me, but CaptonDillWeed??? Come on... I'm surprised... don't you prefer Funky Pups?
Funny, but please don't ruin it for anyone else. Thanks.
Username: Basshead86
Ocala, FL USA
Post Number: 757
Xtreme.Xotic.Xtraorinary. lol
Username: Mike_anthes
Canton, SD USA
Post Number: 301
XXX
CaptonDillWeed
"Unfortunately, unregistered guest votes will not likely be accepted for this reason (above)
Unregistererd voters are still welcome, but I can only do my best weeding through them."
Why would they be welcome if you arn't going accept them (us)? That makes no sence.
"Capton America may have fooled me, but CaptonDillWeed???"
How so would Capton America have fooled you and whats wrong with the name CaptonDillWeed?
"Come on... I'm surprised... don't you prefer Funky Pups?"
What exactly are you suprised about?
What or who are funky pups? Sorry, but I have never heard of them.
"Funny, but please don't ruin it for anyone else. Thanks."
What is funny?
What am I ruining?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 889
My brahma 10" was an amazing SQL sub. When i played something like Guns-n-Roses, it sounded like a set of drums in my truck. The SQ was amazing, and it got loud too.
I went to an audio shop when i first installed it and got it metered. I did a 133 in a box tuned for SQ. The guy that worked at the shop metered his 2 Compvr12's right after he metered my brahma (sealed at the dash)...he did a 134 (his sounded like @$$). He had a kx800.2 and a "special shop-built" box. I had a 1.6 cu ft box tuned to 32hz and a jbl bp600.1 :-)
Post Number: 232
Thanks for all the input thus far...
But if you're reading this for the first time -
Please vote.
Your opinion is greatly needed.
Username: Suleman36
Maryland U.S.A.
Post Number: 2124
I have to add the Avalanche 15 in there also. After extensive testing it definetly is very LOUD and Clean and stays musical at the same time.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 321
Ok heres my vote:
Aurasound 15" sub.
http://www.madisound.com/cgi-bin/index.cgi?cart_id=1516344.9887&pid=98
This puppy rocks, and has exceptional controll. Where do I begin?
It has a neodymium magnet. It has a doubble spider for exceptional suspension controll. It has a 4" underhung voice coil. The Bl is at 18. It has an Xmax peak at 25mm. It has an Fs of 20Hz. Vas is at 169L. Qts of .37. The cone is black aluminum.
Need I say more.
