Amp Problems
NathanR
I bought a package deal off of ebay and i got a force 2800 and two audiobahn abp12t's and the amp went into protect mode so i rewired my box with some 8 gauge (bridged 2 Ohm) and then it worked for about ten minutes but now i turn it off and then on and the subs hit very quietly and then click there goes the fuses (2 25's), i am positive it isnt the ground because it is 2 gauge and i sanded the primer off of my frame and sent a bolt through it. so can anyone please help with this? if you can that'd be great. Thanks.
