lierz Unregistered guest | would someone please explain to me how to hook two dual voice coils to one amp? My subs are 4 ohm, should i hook it up in parallel? |
Gold Member Username: IlluminatorPost Number: 1506 Registered: Apr-05 | You would be best off by wiring each sub into 8 ohms (series) and then wire both of those down to 4 ohms (parallel). RockfordFosgate.com has an online 'woofer wiring wizard' that you can use to see it in illustration. |
lierz Unregistered guest | thanx |
Silver Member Username: Infinity_addictSanta Rosa, California USA Post Number: 152 Registered: Jul-05 | yah, right here. |
