First time setup....need help!!!
Username: y©h¤th
I've got a Rockford P2002 to power 2 12" Boss subs. I don't know if they're 2 or 4 ohm, a buddy gave 'em to me. I don't know what guage wiring to use or how to hook 'em up once I've got that figured out. any help would be appreciated.
Username: Dobaryder
Cocoa, Florida U.s.
Post Number: 18
go to walmart get a cheap amp wiring kit from scoshe there not bad for the price your boss subs are more than likely 4 ohms but if you need to now do a search on the model # from back sub or maybe just the type of boss say
(the ripper)to get some specs on the subs
as far as wiring run power from battery to amp
find somewhere to ground the amp the the frame metal on the car run your rca jack and amp remote on wire from cd deck to amp i would just run them stereo to the amp till you figure out the ohm level and how low of a ohm level your amp will handle
