Glass wolf need help in s.q. setup
Username: Alvingo
Post Number: 9
hi there i have my sound system it consist of a 3.5 inches separates home theater in a kick panel polk audio 20rms X 2. can i set this at 200hz for mids only and tweets? and i have crossfire separates 5.25 for the mid bass should i set this to 90 hz hpf or mid bass 150hz at lpf? and ten inch inverted sealed for the sub at 45 hz. its 2 door 300zx 2+2 coop. is it ok? :-)
By the way I have three amps, the front will be powered by a rockford 2 ch amp that is 22rms x 2 continues watts, the midbass would be a 2channel crossfire amp at 35rms x 2 @ 4 ohms and bridge at 140rms. up to 181rms @ 14.5v..and the subwoffer will have a crossfire 2ch amp that is 525rms. My idea is to drive the rockford at stereo cz my speakers 3.5" are only 20rms so its enough and can get the balancing for the left and right. The next is the crossfire 2ch amp will it be ok to used an Lpad 8ohms then series the speakers for this? so that i can bridge the amp @ 4 ohms. or il just leave it as stereo 35 x2 at 4ohms. cz im using this as mid bass so i need the power for the speakers. We dnt need to balance the midbass right? like a stereo mode??
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9707
sounds fine so far.
how does it sound to you in the car?
Username: Alvingo
Post Number: 10
well I still dnt try it but have you ever tried 3.5 inches in the frontpanel? when you tune your kick panels what frequency range would you normally set? some other people tune them to 80 to 100hz. and with midbass there other people who uses high pass frequency at 120 to 150. which would be better? if I tune the kick panels about 200hz and lpf for mid bass? I have heard that the sub normally if tune to 40hz the valley of the bass would be at 280hz in front of the driver side and the passenger side..is this true? :-)
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9718
8" midbass and 3" midrange, I'd use 700Hz and 4KHz
12dB slope
