Is my amp blown????
Username: Xkawn
Post Number: 58
i was so happy cuz i just finished and everything worked for a few minutes, lol. i partially pulled out my soundstream xta480.4 to do the gain adjustments and i heard like a static like sound and no highs or mids. the volume was at about %75 so i could adjust at a decent volume. my bass amp and subs are working just no mids and highs. the green light is on for the amp so the amp is on..........
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9663
for mids/highs be sure the amp is set for HPF on, and set to about 100Hz
that may be the problem
Username: Xkawn
Post Number: 62
i was about 10 seconds away from buying another amp. you are the man GlassWolf. thanks bro......
