Which is a better amp?
Username: Mister
Alberta Canada
Post Number: 10
would a rockford fosgate amp or kicker amp be highter quality?
a rockford P4004 (100 x 4 watt)
or a kicker 04-kx350 ( 90 x 4 watt )
which will have better / louder sound?
Username: Mister
Alberta Canada
Post Number: 11
or an alpine v-power
MRPM350 (350 x 1 watt )
mono block
Username: Camaro823
British Colu... Canada
Post Number: 182
I personally like the alpine, because its a mono amp so its designed for your subs. It all depends what you want to power the subs alone or maybe subs/speakers.
Username: Mister
Alberta Canada
Post Number: 12
it is for just subs
so the alpine would be best?
Username: Camaro823
Post Number: 183
If your running subs, then yes go with the mono, compared to those choices you listed,(The P4004 is not that great in my experience). I have that alpine amp and I am very happy with it , but its not the greatest if you have hungry subs. What kind of subs you have?
Username: Mister
Alberta Canada
Post Number: 14
what about a kicker 400 watt mono block?
Username: Mister
Alberta Canada
Post Number: 15
2 alpine type S
Username: Mister
Alberta Canada
Post Number: 17
the kicker is a 04KX400.1
400 watt mono block
Username: Camaro823
Post Number: 185
Yes, the kicker would be slightly better. I like your subs , I use to have 3 of them and was very impressed. Anyways I'm assuming you have the new type S, it will do the job but you may want to get a more powerful amp or maybe 2 of either the alpine or kicker for each sub.
Username: Mister
Alberta Canada
Post Number: 18
ok
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9640
any of the three would make a nice amplifier for your system
all are good quality
