Decent 600 watt amp
Username: Matt12490
Benicia, California
Post Number: 116
Can anyone recomend a decent amp that puts out 600RMS @ 2ohms for $175 shipped?
Username: Scubasteve
Annapolis, MD
Post Number: 457
in that range, it looks like you'll be looking for audiobahn, jbl, kicker, or rf. If this is for an sq sub, you'll want something better though. I'm pretty sure its not, but thats just my disclaimer on recommending those amps.
Username: James_g
TN
Post Number: 115
You mean you would put Audiobahn in the same league as JBL and Kicker? Uh.....
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 197
sh!t not sure if its exactly in that price range but the Kicker KX600.1,JBL GTO 600.1,and MTX Thunder 6500D should be close to that price range and all work pretty good...of course thats buying off ebay
Username: James_g
TN
Post Number: 116
The KX600.1 is close, but a little higher. Of course, he should save a little more before buying the Audio...
Anyway, just do a search at eBay with "600" and various name brands. Try Orion, JBL, Kicker, Directed, Memphis, Viper, Alpine, PPI, etc. Just be sure the amp does the 600w at 2 ohms like you specified. Look to Hifonics if you want it really cheap, but a 600w amp rated by them probably won't do the true 600w. You'll have to go a little higher.
zook
Power Acoustik "Gothic" 1200 Watts Max 2 Channel Amplifier
2 x 300 Watts RMS @ 2 OHM
$160 shipped
cardiscountstereos.com
Username: Matt12490
Benicia, California
Post Number: 117
arent 2 channel amplifiers not good for subs unless you bridge them?
Username: Matt12490
Benicia, California
Post Number: 118
If a sub is 4 Ohms DVC does that mean each set of voice coils are 4 ohms? Also, if thats true... can i get (2) 2 channel amps that are 300RMS in bridge mode and bridge a set of voice coils to one and the other set of voice coils to another?
Username: Matt12490
Benicia, California
Post Number: 119
bump
Username: James_g
TN
Post Number: 120
You need to go with a mono amp for your subs.
Yes, if you have 4 ohm DVC subs, then each VC is 4 ohms.
Please do not buy a Power Acoustik amp!
Have you already purchased your subs? If so, what do you have? If not, what do you want?
Username: Matt12490
Benicia, California
Post Number: 121
RE se
