12" Atlas box question
Username: Tpizzle
Post Number: 282
i made a box for my Atlas but i think it may have a leak, i threw it together in an hour. i made it pretty wide and shallow, for my next box i was thinkin about making the width skinnier and depth deeper. does this make a difference or does it not matter the shape as long as the box volume is at the recommended volume?
Username: Basshead86
Ocala, FL USA
Post Number: 532
grrrrr....double posted thread.
when you built the box, did you caulk the inside seams of the box?
and i don't think it makes that much of a difference, but i wouldn't build a box that was long and skinny.
Username: Tpizzle
Post Number: 285
ya i caulked it pretty good there might not be a leak i just wanted an excuse to build another box
Ocala, FL USA
Post Number: 535
haha, then go ahead and build another one. lol
