sam magz
Friday, August 12, 2005 - 03:03 GMT should i get a 2-channel?...2 seperate mono amps, 1 for each sub? what do you guys think?? each sub is 500 RMS so you guys know...
Username: Dominirica012 Charlotte,
North Carolina
US
Post Number: 704 Registered: May-05
Friday, August 12, 2005 - 03:13 GMT what voice coil configuration are the subs and also whats your budget?
North Carolina
US
Post Number: 705 Registered: May-05
Friday, August 12, 2005 - 03:19 GMT Single 4ohm voice coil JBl GTO 1200.1 Alpine MRD-M1005 MTX Thunder 1501D Dual 4ohm voice coils Kicker KX1200.1 MTX Thunder 942.2 all of those subs are from 300-400 dollars on ebay although you could possibly get them even cheaper and all are good quality amps
North Carolina
US
Post Number: 707 Registered: May-05
Friday, August 12, 2005 - 03:20 GMT i said "all of those subs.." meant to say all of those amps lol
sam magz
Friday, August 12, 2005 - 03:27 GMT a range in prices would help..im pretty unsure of what i have to spend...so a good range of prices would be appriciated... dual voice coil... heres all the specs - 12" Type-R Series Subwoofer (4ohm + 4ohm) Frequency Response: 24Hz -- 500Hz Kevlar Reinforced Pulp Cone Custom Cast Aluminum Frame with Integrated Perimeter Venting and Heat Transfer Plate Dual Voice Coil Design Mirrored Progressive Nomex Spiders with Reinforced Layer Integrated Tinsel Leads Compound Radius Curve (CRC) Motor Structure Multi-Stage Thermal Management System HAMR Surround and Concealed Mount Gasket Aluminum Airflow Motor Cover Insert Push Terminals with One-sided Layout let me know if theres anything else you need to know....
sam magz
Friday, August 12, 2005 - 03:33 GMT thanx 4 the help... any1 else know of any good amps to use?
North Carolina
US
Post Number: 717 Registered: May-05
Friday, August 12, 2005 - 03:58 GMT another one is Elemental Designs eD.9 1200rms @1ohm for $350
Username: Livinloud7 Post Number: 40 Registered: Jun-05
Saturday, August 13, 2005 - 00:25 GMT JL 1000/1 Series amp, would be great.. if you have the $.
Username: Xdrummer03 Tenessee
Post Number: 118 Registered: Jul-05
Tuesday, August 16, 2005 - 04:43 GMT I would do two MRD-M605.
Friday, August 19, 2005 - 00:58 GMT Don't the two MRD-M605 underpower the two amps by 200 Watts RMS each?? (it's listed at 300 RMS @ 4ohms while each sub is rated to have 500 RMS @ 4 ohms) Just asking because I'm new to car audio and am also looking to buy an amp for the two same subs and saw this thread. Any other suggestions would be helpful too.
Username: James_g TN
Post Number: 58 Registered: Jul-05
Friday, August 19, 2005 - 01:12 GMT I think the MRD-M605 is 600w RMS X 1 @ 2 ohms.
Friday, August 19, 2005 - 03:50 GMT But does it matter that the subs are rated 500w RMS @ 4 ohms?
started this thread..ha
Friday, August 19, 2005 - 04:21 GMT yea^...it matters..lol..they are 4ohm DVC's.. i started this thread a while ago...lmao..i got the mb quart RAA1000...1000 x 1 @ 1ohm...it gives you every bit of thoe 1000 watts its rated at..
