SQ box
Username: Shouder
Wisconsin
Post Number: 43
I looking to build a new box to custom fit into my car. Right now I have two 10" Kappa Perfects 10d VQ's subs in .5cuft/sub. Right now the way they are set up I get pretty decent Kick. Im just wondering if any one has any ideas on box demensions that would give me even more kick so it hurts. Thanks
Username: Wj94
Post Number: 33
What kind of box do you have for the subs now? I'm buying a 12" kappa perfect 12D VQ sub soon...was planning on putting it in a sealed box, but I need to find a place that makes custom boxes.
Username: Shouder
Wisconsin
Post Number: 44
I made my box myself out of 1/2 inch thick MDF board. Basically it's just 12in by 12in with a <45 connecting the two infront. Just a big triangle. Pretty simple. Check in your manual to see what box you might want, it has a hole bunch of different senerios in there for you. i would recomend something for you but i don't have my manual on me right now ill get back to you.
