Best Sealant
Username: Bdb_86
Bemidji, MN Usa
Post Number: 65
i was wondering what is the best sealant to seal off your speaker boxes so far i have been useing clear silacone is there anything better
Username: Tbone
OK United States
Post Number: 253
I usually use a wood adhesive, that way it not only seals the box, but adds strength. It comes in tubes like silicone, is cheap, and forms a bead like silicone.
