Fiberglass matte v Fiberglass cloth
Username: Schnizo
Post Number: 21
I'm doing my first fiberglass project im molding around a current center counsel for the arm rest shape. everything at this point is cosmetic. Can I use fiberglass cloth instead of matte. I have all kinds of individual pieces of glass from the matte going everywhere. Will the cloth be smoother to work with?
grease dog
the cloth will lay alot better than the matt, but its still harder to lay the cloth around areas that have odd curves, your best bet: lay the cloth on straight runs, lay the matt on corners, either way you will end up sanding down.
