Amp always in protect
kickertakedown
ok got this amp and its a lighting audio amp yea i know its a sh*t amp but all i can afford right now its a 1000 watt mono block amp with the froint bass control and for some resoen when i hook it up its always in protection even with no rca or speakers hooked to it so if you have any idea let me no and i know the grounds good becuase its had my lastamp hooked to it
Username: Tbolt
Collipark, GA United State...
Post Number: 524
Did you check the fuses in the amp?
kickertakedown
yea i did and even bought a new amp kit no go but the other amp i had works fine in the new amp kit install
Username: Glasswolf
Wisteria, Lane USA
Post Number: 9111
if the last amp worked, and you just swapped this one into place and it doesn't work.. that'd tell me you have a bad amplifier.
