1000/1vsXenon122.1vsnewOrionvs.Kicker
Username: Schnizo
Post Number: 12
I'm either getting 2 10w6's or 2 10 Eclipse Ti's What amp would you use to power them. JL, PG, new Orion stuff or Kicker?
Username: Jaackdeth
United States
Post Number: 453
Mike did you go here yet http://p079.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=48.topic
And what is your budget, rms of subs, voice coils etc.
Username: Riebread77
Post Number: 508
well I know the kickers and PGs are severely underrated...that could make a difference in your decision...JL the best of the bunch but most expensive...need your budget
Username: Schnizo
Post Number: 14
$750 for the amp. The Tis want 750rms are they worth it the w6's are 400 rms. I all ready have a 500/1 that I'm going to return. I bought it for a single 12w6 but after making the box I don't like how wide it is. I'm rebuiling the center consel of my truck. So i'm going with 2 10's
