Bronze Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 86 Registered: May-05 | I know that everyone on here frowns upon capacitors. What I wanted to know is if they do any good whatsoever. I undertsand they do not take the place of a HO alternator. My question is if i'm only running about 1200 watts RMS would it make a difference whether I had the Cap in at all or would there be a bigger problem and strain on the alt. I have an Optiama Red top battery and and a 1.2 farad capacitor and right now my lights do not dim at all w/ a rockford fosgate bd1001 amp(I plan on adding an amp for mids and highs later). I also have a ps2, a 7" flip down screen and a viper remote start alarm and i have not had any electrical problems whatsoever Is the capapcitor helping any? |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 8998 Registered: Dec-03 | I think everything you want to know, is answered here: http://www.wickedcases.com/caraudio/capacitors.html if it's not, let me know and I'd be happy to answer anytihng I missed. |
Gold Member Username: CarguyPost Number: 3814 Registered: Nov-04 | There's already another thread on here on capacitor. It should have the answers you're looking for including GW's post. Capacitors are not bad. It's usefulness will depend on how's applied. |
Bronze Member Username: UcfsaxmanOviedo/orlando, Fl Post Number: 87 Registered: May-05 | Ok thanks guys I'll think I'll be fine I don't expect my capapcitor to act as Ho alt. If I ever have any electrical problems then i'll get a HO alt. |
Bronze Member Username: Pricey1985Sydney, NSW Australia Post Number: 18 Registered: Jul-05 | Your page on capacitors is excelent glassy. Interesting to read. |
Gold Member Username: GlasswolfWisteria, Lane USA Post Number: 9034 Registered: Dec-03 | thank you. I'd hoped to cover stuff I saw asked most often to save some time. |
