JL 500/1 or Audiobahn A1300HCT
Username: 2pacalypse1971
Sandusky, Oh
Post Number: 8
yeah as of now i have a rockford power hx2 12 which is rated at 1000 rms....my problem is...it is a dual 2 ohm subwoofer so i have to run it at 4 ohms or 1 ohms...and i plan on runnin it at 1 ohm...the jl 500/1 says it puts out 500 watts at 1.5-4 ohms...but i was thiking about selling it for a Audiobahn A1300HCT which is 1 ohm stable and puts out 1200 watts at 1 ohm...i know not too many people on here like audiobahn amps but i've had good experiences wiht them...and i also knwo i doubt it will put out the whole 1200 but the sub is only 1000 rms so u think i should stick to the JL or sell that and try to get this Audiobahn...thanks
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 31
The Audiobahn only puts out 300 rms the 1200 is the rated max, If you are on a budget go for the audiobahn but I would save my money and get something bigger, if not stay with the JL
Sandusky, Oh
Post Number: 9
it says it puts out 300 rms at 4 ohms...i'm planning on running my speaker at 1 ohm which the amp is rated at 1200 rms....im pretty sure since its a mono amplifier 1200 or something near it will be the output power of it....not 300 rms
Username: Jaackdeth
United States
Post Number: 440
RMS (Continuous) Power: 1200 watts x 1 @ 1 ohm
RMS (Continuous) Power: 300 watts x 1 @ 4 ohm
RMS (Continuous) Power: 600 watts x 1 @ 2 ohm
Sandusky, Oh
Post Number: 10
so u think i should try to hit the audiobahn up or keep the 500/1....im sort of leaning towards teh audiobahn because i just got rid of the audiobahn A2300HCT 2 channel amplifier and it was real powerful....but i would just like your guys opinions
