What Amp should I get?
Username: Spants
I'm looking for a cheap amp..but still work quite well. I bought 2 pyle blue wave 1200watts, 4ohm subwoofers.
Is this an ideal amp for them?
http://shop.store.yahoo.com/discountsonline/pyplcaram.html
Username: Jron
Post Number: 51
man people on here are going to tell you to drop the subs if you can, and not to get that amp either. Alpine, Kicker has some nice subs. look into the Alpine Type R's or the Kicker Comp VR's. Kicker,JL, Alpine, JBL, are also some good amps to look into.
Username: Spants
why should i drop the subs?
Username: Camaro823
British Colu... Canada
Post Number: 149
http://p079.ezboard.com/fcaraudiotalkfrm27.showMessage?topicID=48.topic
This is a list compiled by someone very experienced with car audio
Username: Suthurnlatino
Post Number: 22
Hope you can still return those subs. As far as I can remember I've read that Pyles are poorly made. I've heard flea market brands before but not specifically Pyle (It was DHD aka Alpine knockoff amp brand) but they sounded mechanical and shallow. The sub just had a dirty sound to it.
Username: Kainaliuboyz
i got 2 kenwood 10 inch subs, 500w max a piece, what would be a good amp to get or how many amps do i need for it to work real good?
Username: Jron
Post Number: 52
you need to get the rms rating on the subs first, not the max. I dont know exactly how much power those require, but go by the rms not the max watts, or you will fry the subs.
Username: Jaackdeth
United States
Post Number: 422
usally they are about half what the peak is, but like ^^ said, you need more info!
