Quick headunit question
Username: Eddiebeltoe
Post Number: 25
hey i have a quick? i recently installed a jvd cd headunit and at times i hear a whining or humming sound from my speakers i checked all my wires and harness everything seems to be ok i also checked the fuse on the HU but it still happens out of no where what might be the problem thanx alot guyz
Username: Mikechec9
Chicago/atlanta
Post Number: 630
check your ground. if you tried to ground the black wire yourself, that's likely the issue. if you just connected the jvc black to the harness black, then you should follow the following:
http://www.mobileaudio.com/rac-faq/rac-faq_2.html#SEC7
