Bronze Member Username: Josh2289Post Number: 14 Registered: Jul-05 | Ok this is a drawing i made up this is from what i have read about dual voice coil setup please tell me if this digram is correct. ![]() |
Bronze Member Username: Josh2289Post Number: 15 Registered: Jul-05 | Or should it be like this (for both subs) ![]() |
Silver Member Username: 54danny54Post Number: 807 Registered: Nov-04 | lol man i dont get ya drawing...man just keep reading www.bcae1.com because i swear...i used 2 not get that stuff so i read it once and thought about it 4 5 mins and did that 10 times and i got it |
Bronze Member Username: GhowardsClark, SD USA Post Number: 21 Registered: Jul-05 | can you do a series/parallel with SVC or is that just DVC? What are your wiring options with SVC? |
Bronze Member Username: Supraspyder420Sammamish, Wa U.S. Post Number: 97 Registered: Jul-05 | do any subs have dual inputs on both sides? and that would make a 4 channel amp wouldnt it? |
