The amp i bought syas it needs an 8 gauge kit with ground, can u use a 4g or will it be the same thing? I have Infinity Reference 7341A amp. Thanks again
as long as the wire is oxygen free copper it shouldnt really make a difference. You likely wont even be able to notice the difference between the Power Acoustik and the Knu Konceptz
I made the mistake of buying a power acoustik amp kit, it was suppose to be 2 gauge, and my 4 gauge from Knu Konceptz was much thicker and better, beware~!
