Bronze Member Username: Red_alert05
Post Number: 13 Registered: Jul-05
Posted on Do you need a subsonic filter on your amp if you have a vented box |
Posted on Yes |
Silver Member Username: Alias747
MN
Post Number: 588 Registered: Apr-05
Posted on Dub is right, you only need a subsonic filter for a ported box. If you have a sealed box you can just turn it off. |
Wisteria,
Lane
Post Number: 8860 Registered: Dec-03
Posted on on a ported box, set the subsonic filter to the same frequency as the tuned port.
