Jl 10w3v2 in a dodge ram 4 door
knick
do you think a jl 10w3v2 would be a good sub for a small box under the seat or would you go with something different. Im mostly looking for sound quality but still want to feel it. Also would it even be possible to get higher spl in such a small box.
knick
also want to metion ive only got about 350rms of power
Username: 1bads10
i think a 10 w-3 is a perfect match is you want quality and a decent amount of spl,you can always get a bass cube for added spl
knick
Thanks Ive decided to go with the 10w3v2. But I was wondering what do you mean by a "bass cube", and how much space will it take up.
