High output alternators
Username: Acevolkov
Springfield, Missouri United Stated
Post Number: 14
i was wondering if any of you guys had any advice on high output alternators for a 1994 subaru legacy. i cant find one anywhere, and im looking for about a 170+ amp alternator. ill have the alternator charging an optima yellow top, and that will be powering 3 JL 1000/1 amps. any advice or links to get me headed in the right direction.
Username: Addicted2bass
Miami, Florida USA
Post Number: 928
have you tried www.mralternator.com
Username: Riebread77
Post Number: 384
I had mine built by dominick iraggi...he only builds 220+ though...
dominick@tds.net is how you can contact him if your interested.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8667
www.excessiveamperage.com
talk to Nathan
Username: Subfanatic
Ky
Post Number: 4619
since were on the subject, can a 200 amp alternator but 2 batteries efficiently
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8688
huh?
if the batteries are isolated, a 200A alt will recharge them just fine as long as the audio system doesn't draw over 200A when you're using it with the car running..
was that what ya wanted?
greasedog
would it be just as good as taking my stock alternator somewhere and have it rewound to a higher amperage? theres places in L.A. thatll do it for like 35 bucks
affidavit
bump it up!
Username: Suleman36
Maryland U.S.A.
Post Number: 1826
www.excessiveamperage.com / nathan will have you set.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8750
you could get one rewound to a certain point, but that's limited in how far it can be beefed up.. after that you need a different casing with better venting for heat.
Username: Acevolkov
Post Number: 20
yu could just put a bunch of fans blowing on the heatsink. j/k
