Making box for 2 P3 subs.. help.... thanks
Greggs
ok i'm wondering what thickness of wood i should use.. i'm going to use MDF and make a simple sealed box.... what type of dimensions should i look for...
i have a audiobahn amp that is 300 rms at 4 ohm , 900 rms at 2 ohm, and 1200 rms at 1 ohm.. how do i set up everything to get max output...?? thanks
Username: 54danny54
Post Number: 766
use 1.5 inches thick.........
ok seriously, whatever u can fit man and .75 inches
Username: Dz43893
Chicago, Illinois United states
Post Number: 192
how is this spl and sq on those p3's
