What do you think about this amp for:
Username: 78elcaminoman
Dallas, Texas United States
Post Number: 22
what do yall think about this amp to power 2 RE SE's 10in i think they are like 600rms apiece, and 1200 watts max apiece, and they are dual 4 ohm voice coils:
* High current operation
* VU meters (power level)
* Cooling fans
* Line output For system building
* Gain control
* Power and Protection LEDs
* MOSFET Power supply
* Max power: 3000w
* RMS power, 4ohm@.01% THD: 350w x 2
* RMS power, 2ohm: 700w x 2
* RMS power, 1 ohm: 1000w x 2
* 1/2 ohm Stable stereo Power: 1500w x 2
* Frequency response (+/- 3dB): 9Hz to50kHz
* Signal-to-noise ratio: >105dB
* Channel separation: >90dB
* Low pass Crossover: 50Hz-100Hz
* High pass Crossover: 120Hz-720Hz
* Bass boost: 0-+18dB
* Bass boost Frequency: 50Hz-100Hz
* Dimensions, LxWxH: 20 1/8" x 13 3/8" x 2 3/4"
Username: Bigred2069
Post Number: 58
who makes that
Post Number: 23
BOSS
Post Number: 24
does ne one think it would be good
Username: Mike_anthes
Canton, SD USA
Post Number: 198
no its not a good amp...heres a suggestion...when you put so much money into subs try to match that money into an amp...
Post Number: 25
what amp do you recomend
Post Number: 26
what about this amp:
1 Ch.
4 ohm RMS - 900
2 ohm RMS - 1400
Mono RMS - 1800
Bridged Max - 2400
Dimension W x H x D - 15 x 2.25 x 11
Hi Speed Digital Circuit
Fully Regulated PAM Power Supply
Full Selectable Crossover Hi/Full/Low
Four Way Protection Circuit
1 Ohm Stable Stereo
Bridging Synchronization
Variable Low Pass 50Hz-150Hz
Variable Subwoofer EQ @ 45Hz
Phase Switch 0-180
Remote Dash Mount Low Level Gain Control with Cable
Frequency Response : 15Hz to 150KHz
S/N Ratio :100dB
THD : 0.5%
System Distress Indicator
Inputs Sensitivity : 200 mv - 8V
Dual Mono Speaker Output Connectors
Gold Plated Heavy Duty Power & Speaker Terminals.
Post Number: 27
see but the crazy thing is, is that this amp right here is pretty bad azz:
·Mono Block Subwoofer Amplifier ·1 Ohm Stable ·MOSFET Power Supply ·PWM (Pulse-Width-Modulation)System ·Glass Epoxy PCB ·Gold RCA Inputs ·Custom Terminal Block for Speaker ·Connection ·Thermal,Overload and Short Protection ·Variable Subsonic ·Filter ·(15Hz~40Hz,24dB/Octave) ·Phase Control 0-180 degree ·Remote Bass Control ·I·nput Impedance :10K Ohms ·Soft Turn On/Off ·Advanced Protection Circuitry ·S/N Ratio:?90dB ·Heavy Duty Power Coated Heatsink ·Dimensions:11"(W)x 2"(H)x 17"(L)
Post Number: 28
or what about theis amp:
1x600W RMS at 4 Ohms ·1x1800W RMS at 2 Ohms ·1x3600W MAX at 1.3 Ohms ·Mono Block Subwoofer Amplifier ·1 Ohm Stereo Stable ·MOSFET Power Supply ·PWM (Pulse-Width-Modulated) System ·Double Sided Epoxy PCB Circuit Board ·Gold Plated RCA Inputs ·Custom Terminal Block for Speaker ·Connections ·Thermal, Overload & Short Protection ·Variable Low pass Filter ·(50Hz~150Hz,24dB/Octave) ·Variable Subsonic Filter ·(15Hz~40Hz,24dB/Octave) ·Phase Control 0-180 Degree ·Remote Bass Level Control ·Input Impedance:10K Ohms ·Soft Turn-on/Turn-off ·Red Lighting Illumination ·Side Leg Mounting ·THD: <0.1%.>90dB ·Input Sensitivity : 200mV ~8V ·Freq. Response : 15Hz ~ 150KHz ·Patent Pending ·Heavy Duty Power Coated Heatsink ·Dimensions : 8.6''(W) x 2.74''(H) x 15''(L)(CAN THIS SUB BE ABLE TO RUN THOSE TO SUBS OFF OF IT)
Username: Iufan4lifeul
Louisville, Kentucky
Post Number: 285
Stay away from Pyle, lanzar, legacy, Boss, Sony, etc. just to name a few. You are going to have to put some money into it for a good amp, here is a suggestion... Kicker 1200.1 would be PERFECT. Also an Ed nine.1 would run them perfect. The Ed nine.1 costs about $350 and is the cheaper of the 2.
Post Number: 29
out of the 2 that u told me about which is better and howw much is the kicker
Post Number: 30
i found the kicker 1200.1 amp on ebay for 300 bucks!!!!!!!!!! thats not bad at all
Username: Ffxdevilarms
Dubuque, Iowa United States
Post Number: 737
Are you fooling with us Antonio???? Seriously, how could you possibly pull 4 krappy amps out like that and ask us if they were good. Try the search option on this board and google if you wanna know if a brand is good.
You can get the kicker on ebay for only 315, and i would go with kicker instead of the ednine.1 because i have heard that there are build quality issues with the ednine's. Plus its cheaper.
Post Number: 31
hay man im sry but im new at this man i dident know if they were good or what, like i said man im new at this this is going to be my first system
Post Number: 739
Sorry man, it just seemed kind of like a joke post the way you kept throwing amps up without a response from other people.
Get the kicker if you want a GOOD amp and the RE's. Anything RE is fantastic.
RE does make an amp that putts out 1200 watts at 1 ohm ya know. I think when you get the subs you should ask how much the amp costs, it is the 12.1.
Post Number: 32
i dont think that there amp will work but its kool i think im gunna get the kicker do you think this sub system will rock my 1978 El Camino
Post Number: 740
what do you not think their amp would work????????????????????????????????????????????????????????????????????
Post Number: 33
i thought it dident have enough power
Post Number: 34
ok never mind how much is it i see that it does now
Post Number: 741
It puts out 1200 at 1 ohm, which would give each sub 600 watts. That would be a perfect amp, and it would look cool next the SE's to boot.
Post Number: 35
do you think the RE SE's 10in subs, kicker/RE amp will make my sub system rock my el camino
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 68
Ya it should SQ should be real good but it won't sound insanely deep like 18's they are 10's after all. If what you want is clean acurate tight bass then you will be pleased.
