Running 2 batts?
audio1
i have a 180A alt and i want to run a second batt(yellow-top) for my audio system. Do i have to use an isolator or can i just wire my starting and yellow-top batts in parrallel?
if i need an isolator, please recommend one and tell me how to wire this all up.
thanks
audio1
Username: Firlefanz
Post Number: 37
Go for an isolator, otherwise you might empty your battery when hearing with engine off.
Cannot recommend one cause i am sitting in Europe.
Username: Winn
Santa Ana, California US
Post Number: 97
yes, you need an isolator, there is a few brand that is recommended but the good one is Orion..
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26item%3D5792678203%26&sspagename= STRK%3AMEWA%3AIT%26
or go to www.ebay.com and find out.
