Amplitifer power question
Username: Jeze
Post Number: 42
Is the ACC wire that comes from the ignition to the amplifer have enough current to run other DC electronics from it?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8624
eh, like what?
if that's a remote wire from a head unit, absolutely not.
if it's an ACC feed from the fusebox, it depends on wire gauge, and current rating on the box's fuse
Username: Winn
Santa Ana, California US
Post Number: 90
no, it doesn't. check your car fuse box, the ACC wire stereo from ignition usually only carry 10Amp Fuse. 10Amp fuse doesn't carry enough load for most of External Amp.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8628
holy crap I must've misread that
are you running the amplifier's main power from the ACC wire of the fusebox?
never do that.
run the proper gauge power and ground cables, and run directly to the battery for positive.
no exceptions.
Username: Riebread77
Post Number: 371
glass, what are other sources of the remote wire other than the one off of the headunit?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8638
nothing really for remote since the remote trigger should turn devices on with the head unit..
but you can in a pinch use a switched ignition line.. that turns everything on with the keys in the ACC/RUN position
Post Number: 373
I'm about to do an install...3 amps, audiocontrol DQXS, epicenter, matrix, ddc...total of 7 items...i'm going to assume that all of these can't run off the remote wire off the headunit...am i right?...how could I wire it so that it so that I won't blow the remote transmission from the headunit.
Username: Brynm
Prince Albert, SK Canada
Post Number: 22
run the remote lead off yor HU to a relay coil then your elecs can get the remote signal from the relay
Post Number: 375
if the relay was hooked up to 2 things...wouldn't it power one or the other?
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8641
www.the12volt.com has free diagrams for wiring relays for this purpose.
Post Number: 376
yea you had a different site available too...i checked up on it and played with the interactive situational diagrams and thats all it showed picture wise...ill check up on this website.
