Box measurements for a Sony xplod 12" subwoofer
I need box measuremments for 2 sony 12" subwoofers please. Please Help! Thanks...
Username: Illuminator
Post Number: 1201
We need a model number, Wess. The manual that came with the subs should specify the cubic volume they need. Then you can go from there.
XSL122P5, I lost the manual... :-(. Should I port the box? If so, Should I port it in between the two subs?
XSL122P5, I lost the meanual... :-(. Should I port the box? If so how big should the port be, and how do I do it?
Username: Jaackdeth
United States
Post Number: 295
Feature Details
Unique cone design offers superior rigidity
Small sealed/bandpass enclosure optimized
Gold-plated Binding Posts
4-Ohm Voice Coil
1300W Peak Power (380W RMS)
12" Polypropylene Cone
2005 Subwoofer Parameters
Specifications
Subwoofers
Speaker Size (cm): 30
Speaker Size (inch): 12
Peak Power (W): 1300
Rated Power (RMS, W): 380
Impedance (ohms): 4
Sensitivity (dB/W/m): 89
Frequency Response (Hz): 18-2k
Mass (kg): 5
Mass (lb/oz): 11/0
d (mm): 250
d (inch): 9.8
Rdc (ohms): 3.3
Fs (Hz): 24.8
Qts: 0.37
Qes: 0.39
Qms: 7.02
Vas (Lit.): 86.7
Vas (Cu. ft.): 3.06
Mms (g): 162.1
Lvc (mH): 1.1
Xmax (mm): 5.7
Xmax (inch): 0.2
BL (Tm): 14.1
Subwoofers - Enclosures
Sealed Enclosure Vol. (Net Cu. ft.): 1.15
Sealed Enclosure Vol. (Net Lit.): 32.7
Ported Enclosure Vol. (Net. Lit.): N/A
Port Dimensions (inch): N/A
Ported Enclosure Vol. (Net Cu. ft.): N/A
Port Dimensions (mm): N/A
You could have done the same thing via Google~!~
Thanks, what type of box should I go with?
Username: James1115
Wilton, Ct
Post Number: 3720
well since they dont give the ported recomendation I would have to say sealed.
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 623
since those subs dotn have almost any SQ you might as well go ported so you can be even louder and sound like even more @$$....
Username: Iufan4lifeul
Louisville, Kentucky
Post Number: 274
DON'T GO PORTED, THEY AREN'T MEANT FOR IT. Sealed is double the SPL of ported when your talking about Sony's. I had my 2 in a ported box to begin with and couldn't get very loud and couldn't punch at all. Now, in a prefab sealed they are twice as loud and have gained a little punch.
Username: Kd7nfr
Montpelier, ID United States
Post Number: 590
Twice as loud? Wow.
Post Number: 631
did you have one of those sealed/ported boxes..those dont work for porting because subs need more room when its a ported enclosure and those are made for basically sealed specs so the susb dont have enough room to breathe and all you hear is air moving throuhg the port
So If I wanted to be as loud as possible, which one do I use?
