Matching subs and amps
Username: Jnova80
Newmarket, Ontario Canada
i was looking at a JL audio power handling chart and they show certain subs to go with certain amps and that if you put a 1000 watt amp to a 200 watt sub..the warranty is void, is it just cause you "can" blow the subs if you turn it up to much or should you realy have a 200 watt amp on a 200 watt sub?
