5.1 system
EternaL-AlukarD
I am about to buy this set for my ca theater.
center: 2xinfinity kappa 462.5 cfp
orion amp 2002
front: 2 spk revak 80w + 2 infinity kappa 32,5 cf
orion 8002 amp
rear: 4x infinity reference 9603i
soundstream tarantula TR880-2
sub: 2 x infinity kappa perfect 12.1D
2x orion 600d
any suggestion is welcome
I buy from indoAudioElectronics on ebay beacouse i am from italy and i find all of this here.
My budget are limited to this set.
thanks a lot
Username: Riebread77
Post Number: 363
why don't you sell the soundstream and get another orion...seems like the orions are having a threesome and the tarantula is just hanging out by itself...get another orion to match since you already have 3 of them...much better looking install.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8600
for DD/DTS you want equal power to center, fronts, and surround/rear effects.
consider the a/d/s 6 channel amplifier as an all in one solution for the components, and use a second amp for the subs.
you'd have a total of 9 amplification channels so you could basically drive center, fronts, rears, and subs from one amp, or even bridge any combination of channel pairs you wanted for added power to different channels.
EternaL-AlukarD
Really i don't know where i can find one.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8630
a/d/s is owned by DEI, same as orion, PPI, directed, and Viper.
any DEI dealer can probably get a/d/s products.
