Burping jl audio
Username: 1bads10
im running a jl 18 w-3 dual 4 its at a 2 ohm load to an alpine m 1000. its a 5 cubic foot box with dual 4" ports at 8 and 3/4" long and at high volume its burping.ive tried everything,this is killn me
Username: Riebread77
Post Number: 335
burping isn't really a problem if that's what your going for (max output)....SPL contests use "burps"...so what exactly is your problem. You have to be more specific.
Post Number: 336
Username: Audiobass10
Cape Coral, FL United States
Post Number: 188
I think your confused about what is acutally happening. Burping is used in SPL comps playing test tones in order to get the most out of their subs. It has nothing to do with musicality at all.
Username: Kd7nfr
Montpelier, ID United States
Post Number: 553
I think he means it's bottoming out...
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 585
well maybe you shouldnt be playing at such high volumes..,lower your gain some
Username: Insearchofbass
Post Number: 3402
If your bottoming out and you keep that up it wont be long before you damage your speaker so dont play it like that. What quick shot suggests is a good idea.
