Can you bridge a 4 channel amp?
I have a 760w 4 channel amp and I was wondering if there is any way to bridge it into 1 15in JL Audio sub?
Username: Alias747
MN
Post Number: 563
No, you cannot briged a 4 channel amp down to 1 channel. You can bridge it to 2 channels, but that is about it.
Username: Glasswolf
Wisteria, Lane USA
Post Number: 8608
if the sub is a dual 4 ohm coil sub, you could bridge the amp to 2 channels, then put one channel to each coil.
otherwise, not possible.
just go buy the right amp for the job.
